Optical connection options
Discussion in 'Blu-ray & DVD Players & Recorders' started by Steveford77, Mar 12, 2005.
  1. Steveford77
    Steveford77
    Feb 26, 2005
    17
    Tonbridge
    Just replaced DVD player with a Panasonic DVD recorder. It only outputs Optical as does my Sky+ box. The trouble is my Aego P5 amp only has one optical input.
    It seems that I could get an optical switch or an Optical to Coaxial converter.
    Any advice on the best option?
    I have managed to connect the Optical connection to DVD and output the Sky audio as passthrough. The trouble it is out of sync with the picture. Might I be able to manage with just the one output as another option?
    Steve
  2. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    Steve
    If you have a spare coaxial socket, which your post suggests you do, then get an optical to coaxial converter from Maplins, or do a web search, about £15. This will enable your amp to do the switching and give you full DD when available on Sky+.
    Optical switches are also available, again Google will help here, slightly cheaper but you will have to switch sources manually.
    Wackojacko32
