Optical connection between amp & DVD, is it any good ?
Discussion in 'AV Receivers & Amplifiers' started by kennrc, Jan 14, 2003.
  1. kennrc
    kennrc
    Hi !
    I'm the happy owner of a Sony STR-DB1080QS reciever and a Sony DVP-NS700 DVD/CD/SACD-player. Today they are connected by a coax-cable. I'm very happy with the sound when playing both DVD's and CD's.
    But now I need the coax-plug on the reciever for a digital connection with my PC.
    Both the DVD and the reciever support optial-connections. Therefore I now intend to connect the DVD and reciever by a optical connection instead.
    The question is: Will this give me the same quality sound as the coax does ?
    I've seen several people (including the Sony manual), that recommend using the coax, because this provides the most direct route !?!
  2. Demon
    Demon
    Dec 13, 2000
    956
    Cheltenham
    +57
    Both cables carry a digital signal, and its this very fact that mean there is no difference whatsoever between the two,
    The only difference could occur if you were unlucky and had a bad cable, but this is unlikely.... Digital signals in this situation are extremely robust to noise, and I suspect if you were losing any 'bits' due to the cable, it would manifest itself as gaps in the sound, and other horrible artefacts...
    I am going out on a limb here, but I suspect anyone that tells you they can hear the difference is either
    A. Very much lying
    or
    B. Talking CAK
    - of course if the AMP is damaged, or the cable is, then sure, but this could happen to either...
    Oh and I;ve looked at several schematics for the Optical/Coaxial outputs on DVD players, and as far as routing is concerned, they are identical... they usually just split just before the sockets...
  3. CJROSS
    CJROSS
    Nov 16, 2000
    5,072
    +343
    Ken it is not regarded to be that critical in AV DD 5.1/DTS signals what type of cable type or connection type you use as the signal is [generally] regarded to be less prone to the effects of cable type or connector.
    But … If you are transferring music signals ie PCM coaxial is again generally more highly regarded than optical. So there is a difference, and I hope “I aint very much lying or talking CAK” when I say I have heard differences in these connections.
    BTW Here is an excerpt of my TAG DAC manual about the Optical toslink connection :
    I would take TAGs word for it that both types of connection vary and they may impact on sound, use a coaxial where you can but optical is just as accpeptable in certain types of transfer is bitstream.
    HTHs and of ocurse All IMHO.
