Optical/Coaxial digital audio output ?
Discussion in 'AV Receivers & Amplifiers' started by pmk, Jul 31, 2003.
  1. pmk
    pmk
    Can any one help me with a slight problem I have? I have just bought a Philips DVD733 player. The problem is that this player has a "Coaxial Digital Out" Which is different to the player I had before which had the fiber optic out.
    As I have the Technics SA-DX940 receiver, the only way I can hook up the DVD is through the normal rca cable (which is not digital):mad:
    And If no help could you recommend a receiver that has this option.
  2. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    Maplin Electronics sell a converter.
    part no. QN17T
    Have a look on their web site http://www.maplin.co.uk/
    look in Sound & Vision - Audio/Video Cables & Accessories - Optical
    or do a search for QN17T
    its £14.99
  3. pmk
    pmk
    Thanks for that, just had a branch open up nearby! But whats the best coaxial cable to get?
  4. Dutch
    Dutch
    Dec 5, 2002
    2,560
    3
    North Yorkshire
    +257
