optical-coax converters?
Discussion in 'AV Receivers & Amplifiers' started by keyser, Nov 24, 2001.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Do you guys know where I can get a good converter from coax to optical or optical to-coax because I have a dvd player and and amp that dont have the same plugs, and what do these gismos cost? Thanks.
  2. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    several are available
    you can try Audio Authority or Midiman
    the later is cheaper and does optical to coax and vice versa
    prices are around 50 pounds
  3. Guest
    You can also try...
    1501721 Optical To Co-Ax digital converter inc. PSU £29.99
    Cornwall Electronics
    Highshore House
    New Bridge Street
    Truro, Cornwall
    (UK)
    TR1 2AA
    Telephone 01872 274154 / Fax 01872 274237
