Optical Cables is there a differance?
Discussion in 'Cables & Switches' started by tankrs, May 31, 2008.
  1. tankrs
    tankrs
    Mar 27, 2008
    103
    Flintshire
    +15
    Hi everybody,:hiya:
    Is there a differance between cheap and expensive Optical cables. I dont want to pay a Monster price ( I`m sure you know what I mean) for a cable if a cheap one will do do the same job. I`m after 2x1m and 1x2m. Any suggestions on best place to buy?
    Tankers
  2. spl23
    spl23
    Jan 9, 2004
    2,671
    103
    +383
    No, there is no difference between cheap and expensive optical cables. Maplin or similar will sell cheap ones that work fine.
  3. Alan Mac
    Alan Mac
    Feb 13, 2007
    1,459
    Highlands of Scotland
    +248
    Cheap optical-fiber cables will indeed work fine for SPDIF connections.
    But even the cheapest optical-fiber cable is considerably more expensive than a cheap RCA-phono plug lead of similar length.
    So if you have the option to choose SPDIF transmitted over co-axial cable then it should be cheaper to take it.
    Alan
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  5. danmc_82
    danmc_82
    Jan 19, 2007
    5,587
    Skynet Border
    +1,161
    I'd spend my money on descent bulid quality as you dont want it to fall apart in your hands.
  6. Alan Mac
    Alan Mac
    Feb 13, 2007
    1,459
    +248
    I agree these are very cheap. But RCA-phono cables are much cheaper still!
    99 pence for 1 m of optical cable with connectors
    29.5 pence for 1.2 m of RCA-phono cable and connectors.
    (You get 2 cables for 59 pence !).
    The RCA-phono connector is also probably more reliable mechanically.
    http://www.cableuniverse.co.uk/catalog/cables/2-rca-plug-to-2-rca-plug-budget-12-metres.html
    Alan
  7. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,270
    Welwyn, Herts
    +932
    I'm not going to take issue with all the regulars around here, but I thought it might be worth metioning that many people have said that glass toslink cables perform better than the usual plastic cables. I am absolutely not going to justify that, so make of it what you will, I'm just conveying what is quite a considerable body of opinion. I now have a plastic and a glass cable, and will do a comparison between them in due course. I don't care which is better, I'll just sell the other one.
    regards, Nick
  8. Alan Mac
    Alan Mac
    Feb 13, 2007
    1,459
    +248
    In an optical-fiber cable, the bandwidth for a given distance is limited by dispersion.
    The bandwidth-distance product for a typical plastic fiber is about 2 MHz . km.
    The bandwidth-distance product for a quartz fiber is typically about 500 MHz . km.
    Which means that for a 3 m long plastic fiber cable the bandwidth is about:
    (2000 MHz . m) / 3 m = 667 MHz
    For a quartz fiber, 3 m long the bandwidth will be about:
    (500 000 MHz . m) / 3 m = 167 GHz
    Both bandwidths would seem “adequate” for SPDIF (!)
    Alan
  9. tankrs
    tankrs
    Mar 27, 2008
    103
    Flintshire
    +15
    Thanks for you replies,:smashin:
    the reason for asking question was i want to output tv sound(46x sony) to amp (sony es3300). So I`ll try both conns to see what works best.
    Tankrs
