Optical Cable
Discussion in 'Cables & Switches' started by briggsy, Jan 14, 2004.
  1. briggsy
    briggsy
    Jan 10, 2004
    54
    Anybody got any recommedations for a good optical cable. My Yamaha 640 only accepts OPTICAL input for some reason.
    Briggsy
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    The £9.99 one at B&Q has had some good reveiws, very cost effective!
  3. briggsy
    briggsy
    Jan 10, 2004
    54
    At the moment I'm just using the one I got with my PS2. Thought I might be able to improve things a bit.
  4. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,257
    63
    Perth, Western Australia (Originally Ireland)
    +228
    The digital inputs on the Yammie are input-assignable, so if you wanted to you could re-assign the CD coaxial to be used as DVD if you wanted to. Also, and I may be opening a can of worms here, but I think most optical cables are the same, in so much as transferring digital audio via light. Obviously more expensive cables have better build quality, durability etc.
    Although I must confess that i tend to buy mid-priced digtal cables because I "think" I am hearing more!!!
    Markie Boy
  5. briggsy
    briggsy
    Jan 10, 2004
    54
    Thanks Markie Boy I didn;t know you could do that.
    I think the difference in the optical is in the toslink socket build .
    Coax is meant to be better.
  6. bobbypunk
    bobbypunk
    no can of worms to open
    i studied physics and one of the things we studied was fibre optics and, there are alot of things you can do to improve fibre optic cables. Wether any of the more expensive ones actually are better is individual
    Qed Qunex @ £30
    VDH Optocoupler @ £50
