optical cable for 5.1 surround sound
Discussion in 'Cables & Switches' started by Ninjack, Sep 17, 2007.
  1. Ninjack
    Ninjack
    hey, i think this is the right place to ask, i'm new to the forums.
    i just recently bought a sony 5.1 surround sound from my brother. the main reason i wanted it was to play my xbox 360 in 5.1. my brother didn't have an optical cable so i decided to go out and buy one cheap (£3). When i got home i discoverd that my 5.1 system didn't have a optical slot so i couldn't connect my 360.
    I am just wondering what cable i would need to connect my 360 if my 5.1 system doesn't have an optical slot.
    thanks.
  2. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    Guessing that your 5.1 system does have coaxial digital in you can get an optical to coaxial adaptor, something like this
    regards
    Brian
  3. Ninjack
    Ninjack
    i'm quite new to this sort of stuff so, how do i know if my 5.1 system has coaxial?
  4. sammy4499771
    sammy4499771
    Mar 12, 2006
    589
    +93
    What model number is it?
  5. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    It should be labelled as something like Coaxial In or Digital In or Aux In (Digital). It will use a phono connector.
    Can you tell us the make / model of the system? that would help
    regards
    Brian
  6. Ninjack
    Ninjack
    uhm i don't knwo if this is right but...
    sony dvd home theatre system DAV-SB100
  7. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    I'm afraid the specs for that system suggest it doesn't have a digital input. It will only give you 5.1 from DVDs.
    You could connect the X-Box to the stereo input but it won't be 5.1.
    regards
    Brian
  8. Ninjack
    Ninjack
    [​IMG]
    um, does this help at all?
  9. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    no, that's for an aerial for the radio tuner. just to the left of your photo looks like where the stereo input will be
    regards
    Brian
  10. Ninjack
    Ninjack
  11. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    Yes, that's the one
    Brian
  12. PWinwood
    PWinwood
    Aug 14, 2007
    81
    Abingdon
    +14
    Sorry but no those are the connectors for analogue audio and composite video.
  13. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,855
    +1,188
    I had the Sony DAV SB100 it was the DVD player I had for years which I just this year replaced it with AV separates.
    It does not have Coaxial or Optical inputs. It only has Red/White Phono. This does not give 5.1 sound. Plus when I connected my PS2 via the R/W RCA method to the SB100 the sound was very duff indeed.
    It was good for watching movies but once I have now tried a separate AV receiver and speakers I would never go back as the sound from these is literally out of this world compared to the SB100.
    Could you not sell it on ebay as it was low grade, i.e cheapest there was, when I bought it way back in 2004 (it was all I could afford at the time). I would suspect it would easily be outclassed, and by some margin, by any 'all in ones' released now.
  14. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    Yes, if you read the whole thread we've resorted to analogue as the only possible option and the OP knows that it will not be 5.1
    Brian
  15. PWinwood
    PWinwood
    Aug 14, 2007
    81
    Abingdon
    +14
    Sorry, You are quite correct. I misunderstood what was going on.
    Paul.
  16. Ninjack
    Ninjack
    when my brother had this system he was able to hook up his original xbox 1 into the surround sound, how did he do this?
    i've tried asking my brother but he is very busy at the moment with uni
  17. Suphix
    Suphix
    Nov 20, 2006
    32
    Hello Ninjack, This is your brother, thought i would find you asking in these forums, We'll to be perfectly honest i don't know how i got 5.1 out of these speakers, I think your best bet is to either:
    A) Look for a cheap AV Receiver and use the speakers that i sold to you (for a very reasonable price)
    B) Look for a cable that goes from optical to LR Phono, Then the sound from you Xbox would come out of the speakers but i think only the Front 3 speakers and Sub, and since i guess you'll be wearing your headset i don't think you'll need to worry much about sound coming from behind you. besides your still be able to watch DVD's in 5.1
