Optical audio or Co-axial audio
Discussion in 'Cables & Switches' started by The Penetrator, Oct 16, 2004.
  1. The Penetrator
    The Penetrator
    I have the option of using Optical audio or Co-axial audio cables. Or even analogue L-R.
    What is the best option to use ?
    What make/model of cable is the best for the job ?
    I'll be using a DVD player connected to a TV.
    Cheers,
    TP
  2. Ian J
    Ian J
    Aug 6, 2001
    25,629
    +4,906
    I don't imagine that you could tell any difference if it for connection to a TV.
    Mark Grant sells top quality cables here where a one metre hand made digital coaxial cable will set you back just £20 compared to many times that sum for similar quality in a shop. The cable may be overkill for your system but for £20 at least that will be one part of your system that will never need to be upgraded
