Optical Audio Digital Out
Bigpants2k
Hiya,
I have a DAV-S880, which has a Optical Audio Digital Out on the back.
Will i be able to connect a optic cable from my X-Box to this to input sound or is this just one way.
:p :p
Bigpants2k
aarrrggghhhhh
So what will i be able to connect to this optic thingy
Thanks for your help
mjn
Originally posted by Flip Flop Fred
aarrrggghhhhh
offboard DAC, external recorder, or another AV amp.
Bigpants2k
Thanks for your help.
fozziebear39
I have the DAV-S880 and I have a PS2 connected through the optical IN. The XBOX should go in there as well, Pro Logic II on all those games...
Ashy
yup, ive got a ps2 connected to the optical port on the back of my DAV and it plays nice 5.1 sound on games that support it. so in answer to your question "YES" :)
Bigpants2k
Thanks Ashy and fozziebear
I have just got to get myself a optic cable now
:D :clap:
andypandy
I too thought the optical port on the back was only an out going signal. I can only presume that the DVD player has a decoder on board which then enables it as an input channel - Still very odd though that it cna act as both in and out.!
Bigpants2k
So wich cable should i go for? a microsoft one which i imagine will be expensive or a 3rd party one, and will there be much differance between the two?.
B
bobbles
the joytech advanced scart works a treat RGB scart and optical out
Bogside
you can get cheap optical cables for Xbox on ebay for £1. Good place to start til you know what you're after.
R
richabir
i thought it was just an optical input if it is an out put as well could someone please tell how to get it to work because i want to connect to another amp the sub is crap
Trending threads
