Optical and Digital Audio Cables
Discussion in 'AV Receivers & Amplifiers' started by maramelia, Sep 15, 2004.
  1. maramelia
    maramelia
    I have a dvd player that has a digital audio cable socket but a home cinema amplifier that has an optical socket. Is it possible to get an adaptor or is there cable with the two fittings at either end available? :confused:
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Maramelia,
    When you say digital, what does the connector look like? Is it a bit like an RCA phono socket with 2 small projections top and bottom? If so it's COAX and will need a COAX connector at the other end. Fibre optic cable cannot be terminated with anything other than a fibre connector. So you may have a problem....
  3. RichardG
    RichardG
    Apr 28, 2003
    198
    Cardiff, UK
    +13
  4. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    Great link,
    Wasn't aware of anything to convert optical.
    Cheers!
  5. maramelia
    maramelia
    Many thanks for the help will get on and order it!!! :clap:
  6. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    What amp are you using that has only got optical in and no coax digital in?
