Sorry if some of these items have been discussed before but I just wanted to clarify and group 2 or 3 together etc. I recently picked up the Opportunity UDP 203 player. I haven't spent a lot of time with it yet, but my initial findings are very positive - it is playing absolutely every video file I have on my NAS system including 4K MKVs etc. Also files that my 4K LG OLED TV and Mede8er struggled with.
My questions are as follows:
Best Regards,
Ian.
- I can find my NAS NFS Share under 'NETWORK' menu. However, I then have to navigate through several folders etc., to get to my 'Movies' folder. Is there any possible way to set my Movies NFS Folder to be a location in Favourites, within the OPPO 'Favourites' section?
- When the 203 sees all my Movie Folders inside my NAS NFS Share, they all appear as just Blue folders. Is there any way to get pictures and metadata into the 203 for all Media etc?
- I have a Marantz Receiver (SR7008 - Non 4K Compatible). So I have my 203 setup with the main HDMI OUT running up to my LG 4K TV and the AUDIO OUT HDMI running to my Marantz Amp. Would I be better off, using the 5.1/7.1 Analog Outputs of the 203 into the 5.1/7.1 Analog Inputs of the Marantz Receiver to take advantage of the Oppo DAC which I imagine is a lot better than the Marantz SR7008 DAC? Is there any downsides to doing this? I have a separate Oppo Headphone DAC and absolutely Love It, so I was happy to see the DAC in the 203 and reckon this is what I should use for playing ALL Movies and ALL Music etc. (My Mede8er will be retired).
- When Listening to HiRes Music via the Oppo (at present via HDMI) - is it best to just listen to the HR Music in a Stereo Mode? Same when connected with Analog connections?
- Last Q - Does anyone have any recommended 'best' settings for connecting the 203 to an LG B6 OLED 4K TV?
Best Regards,
Ian.
