Oppo/Sagem Remote Codes
Discussion in 'Home Cinema Control & Remote Controls' started by Shakey_Jake33, Aug 21, 2005.
  1. Shakey_Jake33
    Shakey_Jake33
    To be honest, I'm not too sure I'm asking this in the right place here... apologies if I'm not =/
    Basically, my LG 26LX2R came with a Universal remote of sorts (an LG one). Now I have never, ever had a universal remote in my life. Basically, I want to program it works with my Oppo Digital OPDV971H DVD Player, and Sagem ITD 62 Freeview box.
    However, the code on the Oppo page is a 4-digit code.... this one seems to take 3. And nothing found about a code for the Sagem.
    As I say, I know nothing about these. I've no idea if the codes are specific to your type of universal remote, or where I should look for the codes.
    Can anyone offer advice?
