Oppo OPDV-971H and PAL discs?
skirpydoink
I recieved this player yesterday and think the picture quality is superb on both PAL and NTSC discs....
The only thing i find slightly annoying with it is, PAL discs with borders on it are uneven.....the top bar is a good deal thicker than the bottom.
Is there any way to remedy this?
Cheers!
kazzup
skirpydoink said:
Cheers!
Do you have a PX60 by any chance?
I've noticed this problem but to be honest it depends on the disc, some are okay whilst others are really bad.
Dont think there is a remedy.
craig777
I experienced this problem with my 42PX60 and Pio 696 via hdmi. Not sure if anything can be done about it.
S
StePye
As bad as that reply sounds, maybe its just Panny's or your Panny.
I had one until recently, it connected by DVI to a hitachi PD7200 and no problems whatsoever.
Panny or unlucky, your choice? Both are bad
C
Captin_Campout
I just bought myself a Oppo OPDV-971H too and see this issue with the vertical borders is one known to many.
Apparently fixed in firmware releases, or due to be fixed...
Similar threads
