Oppo BDP 83
Discussion in 'Blu-ray & DVD Players & Recorders' started by Morty, Jul 11, 2018.
Tags:
  1. Morty
    Morty
    Apr 24, 2006
    283
    46
    +107
    Hi all,
    Just after a bit of advice.I've got a massive dvd collection which has been neglected for years.Dusted them off and thought to myself i'll watch a few.Using a cheap as chips Sony BDP S480 that upscales to a certain degree.The picture isn't the best but watchable considering where the tech was at the time
    I was offered a second hand oppo BDP 83 for not much cash and told it was a good upscaler of dvd media plus the fact i can throw in bluray aswell so no need for 2 machines.Just how good is the upscaling of dvd's on the oppo?
    Thanks in advance.
  2. simonblue
    simonblue
    Jan 29, 2006
    19,965
    163
    +9,064
    Check it out,and if everything working ok go for it,its very good at upscaling :)
  3. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,881
    11
    13
    167
    ::1/128
    +17,129
    It is very good indeed, with 4K now being common I'd also look at the 93 and the 103D and see whether you can get a good deal on those.
  4. Andy Leitch
    Andy Leitch
    Apr 27, 2005
    599
    +92
    The rubber band that opens and closes the drawer will perish over time. It's an easy but expensive fix....£36 from Oppo. Might be worth asking if it's had a replacement band. If not, I'd haggle. ;)
  5. Morty
    Morty
    Apr 24, 2006
    283
    46
    +107
    Thanks for the input.Much appreciated
