Can anyone post a definitive list of changes made by this update?
Cheers.
Steve W
On the Oppo site it says-
Certain SACD discs with many short tracks or with a long track following several short tracks can cause the player to freeze during playback. This version fixes the issue. The crackles and pops that happened occasionally between tracks on some discs are also eliminated.
Fix for the issue of incorrect video size when playing some Blu-ray discs, such as "Patton", "Time Bandits" and "Date Night".
A small number of Blu-ray discs with Dolby TrueHD audio exhibit a momentary audio drop-out issue if the player is connected to an A/V receiver via HDMI and bitstream is selected as the HDMI Audio format. This version fixes the issue.
Support for LPCM audio streaming over home network is restored. The previous firmware did not carry this feature over from older versions. Please note that home network streaming is an experimental feature. You will need a computer running UPnP or DLNA streaming server software that can support transcoding to LPCM in order to use this feature.
The previous firmware version displays the time counter slightly too fast when playing SACD. This version fixes the issue.
Quieter laser head movement for CD playback.
Other general disc and media file compatibility improvement based on recent and upcoming Blu-ray releases as well as user-submitted samples.
All features and improvements of the previous firmware are also included in this version. This version has a known issue - When the TV aspect ratio is set to "16:9 Wide/Auto", MKV files may be played back with an incorrect aspect ratio. The workaround is to set the TV aspect ratio to "16:9 Wide". We hope to resolve this issue with a future firmware update.
i'm quite surprised they released it with known issues,and also its not just mkv's that play back incorrectly....
