Oppo bd93eu problem
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by numpty75, Jan 8, 2012.
  1. numpty75
    numpty75
    Jan 8, 2012
    4
    Hi. Have had my oppo player for a couple of months and have been very impressed. The machine works well but after watching a blu ray I cannot eject the disc from the player using the remote or the eject button. Think I had error code bdmv. Cannot switch player off but after pressing on/off a few times it will eventually respond. Once off I can switch it straight back on and eject disc. Am 2 1/2 hrs away from dealer so need to try to fix myself first. Have latest software on it. What am I doing wrong?
  2. jwsg
    jwsg
    Dec 13, 2002
    428
    43
    +135
    Suggest you post in Oppo 93 thread in the parent forum - this one is for remote MR hacks
