Opinions on the Vivanco Wall Bracket from Unbeatable.co.uk......
Discussion in 'Home Cinema Buying & Building' started by Daipac, Apr 17, 2005.
  1. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Should be getting my new plasma in a week or so and I will be mounting it on the wall so I am in the market for a bracket.
    I have seen THIS bracket on unbeatable.co.uk and it seems good value.
    Anybody bought one of these ? If so, what are your opinions of it ?
    Do you have any other recommendations for a wall bracket ?
    Thanks,
    Dai
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
  3. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Any reason why you would pay £20 more for the non-tilting and £50 more for the tilting one Mal ?
  4. tabs
    tabs
    Apr 3, 2005
    1,974
    warks
    +129
  5. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Just found THIS
    Should have done a search really ! DOH !
    :oops:
    Sounds like just what I need, going to order one now...............
  6. tabs
    tabs
    Apr 3, 2005
    1,974
    warks
    +129
    Daipac...dont forget...use raw bolts to fix it to the wall if its brickwork your going into, :smashin:
  7. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Will do !
  8. jpfrost
    jpfrost
    Jan 18, 2003
    93
    Daipac,
    just wondered what your thoughts were on this bracket? How long did it take from order to delivery?
  9. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    Hi jp. The mount arrived within 2 days of ordering, really good service. I have not put it on the wall yet as my plasma TV only turned up this morning so it should be on the wall 2nite I hope. I will let you know what I think of it once it is up.
