Opinions on sound
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Movieman, Sep 7, 2004.
  1. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    I have just bought a Lexicon DC1 and I am connecting it to a Parasound 1205 THX Power amp and a Pioneer 757Ai DVD player.
    Does any one have any opinions on what would sound best a " Opical or Coaxial conection between the Meridian and th 757Ai". I'm asking as I've never used a Coaxial connection before as my old amp "Yamy A2" never had one.
    Thanks in advance for any advise. :thumbsup:
    Movieman
  2. cameronl
    cameronl
    Aug 13, 2002
    1,151
    38
    +11
    do you mean a lexicon DC1?
  3. Knightshade
    Knightshade
    Aug 6, 2004
    1,996
    +43
    Hi Movieman,
    I use COAX to connect my DAC to CD. I tried optical and found the sound had a slightly lifeless feel to it. I do use optical to connect a cheap DVD player to my system. I tried various cables ranging from £10 - £100ish finally settled on one for about £15 as I couldn't tell the difference between it and the ones for £100!
    Good luck.
  4. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Yes I did mean Lexicon DC1 ( how stupid am I)
  5. Peter Baker
    Peter Baker
    Sep 6, 2003
    623
    28
    LONDON
    +37
    I too use coaxial cable, finding optical loses the life and vitality of the signal
