Bristol Pete
About to buy this set up. probably been asked before, but I cant find any reference to it, so I will ask again.
Anyone out there got this speaker kit.? If yes, can I get an opinion please.
I am currently using -
Sony DVPS735D
Sony STRDB870 Rec'
Mission stancette stands
Also, I would like some advice on rear speaker placement. Room is a fairly long, although almost square room. So, Side, corners, or behind? and how far up.
Are the fronts magnetically shielded, and what is the minimum distance/maximum disatnce I can keep them apart.? ie, either side of te TV.
thanks,
Captain Benefit.
Sony DVPS735D
Sony STRDB870 Rec'
thanks,
Captain Benefit.
