opinions on digital video essentials
Discussion in 'Movie Forum' started by 7 of 9, Sep 22, 2004.
  1. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    what are peoples opinions on digital video essentials?
    and please, please do not ask me to do a search.
    i am thinking about getting both the ntsc and pal versions and before i buy i wanted to know peoples opinions on the dvds
    are the tests accurate, is the dvd easy to use, are the tests easy to use etc.
    thanks from 7 of 9
  2. 7 of 9
    7 of 9
    Apr 16, 2003
    235
    16
    kingswood bristol
    is anyone going to reply to me and give there opions.
    in a few years maybe.
    thanks from 7 of 9.
  3. PeteB
    PeteB
    Jun 21, 2004
    45
    I have the pal version.
    I found it rather difficult and longwinded to navigate, and some of the tests are a bit subjective, but overall it is very worthwile and I ended up with a much better picture.
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    I use the pal DVE disc.
    When you play through it, it gives you instructions on what to do with basic contrast and brightness settings. Also colour ,sharpness, tint and hue controll. It also talks you through basic sound setup as well. MY only problem with the disc is that it also contains a large amount of test patterens that dont have any real explination with them. Most of these though are designed for advanced calibration of your system and unless you have an ISF degree and the proper equipment you wont be using them any way.
    Definatly worth getting though because if you take your time going through it you will get better results from your system :)
  5. stevej
    stevej
    May 21, 2003
    197
    2
    +3
    If you're going to get both PAL and NTSC calibration discs you should definately consider getting hold of AVIA. As I've said before IMO, AVIA is a much better disc, the down side beig that it's NTSC. All of the test material has explanations, and the sub/sound setup especially, p:censored:s over DVE. I use DVE for picture and SB setup and AVIA for the rest.
    Easy peasy! :smashin:
  6. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
    I have to agree with stevej. Apart AVIA does all you will ever need (in NTSC) DVE is a nightmare to navigate and although it produces excellent results you will be tearing your hair out in frustation long before your setup is complete.
  7. Stew
    Stew
    Feb 1, 2003
    52
    I thought it was excellent, really happy with the result it gave me
