Opinions on DDD House as a supplier?
Discussion in 'Movie Forum' started by mellow, Feb 24, 2003.
  1. mellow
    mellow
    I've only used "local" internet suppliers for DVDs up to now, but these guys seem to put out some good deals from Hong Kong.
    Has anyone bought recently from them? - and what are they like for quality & delivery.
    All/any feedback welcome. Thanks.
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    a search for DDDhouse will tell you what you want.
  3. mellow
    mellow
    figner troulbe - double posting not intentional. :suicide:
    Thanks James - had already tried a search on "DDD House" before posting with only one returned. Tried again without space - result!
    The wonders of search engines :rolleyes:
  4. Lux
    Lux
    Nov 10, 2002
    759
    Luxembourg
    I used them twice. no probs at all.
  5. fraggle
    fraggle
    Dec 11, 2002
    1,441
    Milton Keynes
    +29
    Duplicate threads merged & tidied up.
    Richard.
  6. James45
    James45
    Sep 21, 2002
    2,844
    59
    my intention with suggesting a search was to prevent another "what are DDDhouse like?" thread as there are already a few but since that didn't work I will state again that they are very good (cheap, reliable) just make sure you're not buying a pan and scan dvd from them as many seem to be 4:3.
  7. juboy
    juboy
    DDDhouse are good if you're after inexpensive DVDs from a limited choice. Their postage and packaging is second to none though :)
    As James45 says, check carefully what they've listed as the aspect ratio.
  8. Splinter
    Splinter
    For those of you that have ordered from DDDhouse - is it usual for the order status to say "Confirmed" for 3-4 days? Nowhere on the site says what the status means - will it will eventually say "shipped"?
  9. James45
    James45
    Sep 21, 2002
    2,844
    59
    don't pay much attention to that I haven't bothered using that feature since they updated the website late last year. The discs WILL be there within seven days of the order confirmation email.
  10. Splinter
    Splinter
    Cheers mate
