Opinion on Tag AV30R?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by nathan_silly, Mar 4, 2003.
  1. nathan_silly
    nathan_silly
    I'm looking for a good, but affordable AV processor with better software support than the usual korean/chinese made AV Processors.
    How much is this unit new, and will it fit into my Audiolab PX system well?
    Nathan
  2. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    depends on spec,nathan...the base spec unit is £1800.
    For this sort of money you could buy a used AV32R and ensure an upgrade path that leads right up to the AV192R,whereas the AV30R is not intended to provide that.
  3. nathan_silly
    nathan_silly
    What about a 2nd hand AV30R? I'm not bothered with long-term upgrading- I'll probably replace the Tag in 10 years or so- so the AV32R upgradability option is moot.
    5.1 will do me- guess that can be upgraded to 7.1 later on. Don't need HDCD, Mpeg-II or DTS
    5.1 input is important. Pro-Logic II would be nice.
    Nathan:D
  4. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    Can you find one? I've never seen a SH AV30R for sale.
    My vote is still for the AV32R. I went through the same dilemma a couple of months ago. As far as your future plans are concerned, never say never.
    D.
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Fine nathan....I just got the impression(obviously wrong)from your post that you were looking for upgradeability when you mentioned software support.
    Also the bit about a secondhand AV30R.....thought you were looking for new prices....in any case I dont think you'll find used ones yet.
    Perhaps if you tell us exactly what you do want we can help more.
    A visit to the Tag website may be useful www.tagmclaren.com
  6. nathan_silly
    nathan_silly
    The AV30R has firmware upgrades though?
    That's the most important thing, say for instance a bit ago the DTS click caused problems with some processors- and it was fixed.
    Nathan
  7. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Have a look at Tag's website....all that the AV30R has in terms of software upgrades are HDCD,MPEG2 and DTS-ES,all of which you said you werent interested in.
    I have no doubts that Tag will offer some software upgrades as appropriate to the machine's capabilities,but it specifically wasnt intended to be as flexible as the AV32R.
  8. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    Tag do provide firmware upgrades but not for much longer as far as the AV30R and AV32R are concerned. The current firmware version is 3.75. The next version will be 3.80 but that will be the last one for these two machines. Beyond that, Tag will only be developing firmware for the AV32R Dual Processor and AV192R.
    D.
  9. nathan_silly
    nathan_silly
    The Dual processor version is too expensive :( I guess I could get a 2nd hand AV32R, it's in my price range.
    I've heard the processor has the usual Audiolab sound- very clinical, and forward.
    Will this make my system too upfront and harsh?
    I've heard the Lexicons have a warmer and more atmospheric sound (in AV)- do you think this is the safer bet? I guess I can get a MC-1, lacking 5.1 but it decodes DD and that's all I want really. Missing Pro-Logic II, but Logic 7 is supposed to be excellent.
    Nathan
  10. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Whoever said they sound forward probably had it partnered with the wrong ancillaries.....as you can see,I have an AV32R and also B&W 805s....a recipe for a forward sound if there was going to be one....with good amps and good sources,the Tag is a very neutral processor...just dont feed it poor quality source material,otherwise it will simply reveal it.
  11. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    I agree with alexs2 (I think secretly we might both be Tag fans ;)). In my setup, the AV32R is certainly not forward. It sounds very neutral and if anything, I'd characterise its performance as relaxed.
    Try and arrange a couple of demos.
    D.
