Opinion: KEF Q1 vs MA Bronze B2
Discussion in 'Home Cinema Speakers' started by Falp, Feb 16, 2005.
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I know i'ts a difficult question but whats your opinion:
    Are the KEF Q1 better than the MA Bronze 2? In what if possible?
    I have my doubts on the Q1s about bass control... is this true?
    And the Focal Chorus 706S if you know them?
    Thanks! :thumbsup:
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Come on guys... MA B2 vs KEF Q1.... no one... :confused:
  3. greg_SA
    greg_SA
    Jun 30, 2004
    177
    Cape Town
    +16
    Both are great... take a listen to them :D
  4. yant
    yant
    Dec 8, 2002
    264
    28
    +32
    Don't know if that's any help. I like the Kef Q1 but I slightly prefer the Monitor Audi Silver S1. I rate both as good speakers.
    I haven't listened to the B2.
  5. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I like the MA S1 very much!
    My options are:
    Level up - Quad 12L+11L / MA S2+S1
    Level down- Kef Q1+Qcompact / MA B2+B1 / Focal 706s+705s
    front/rear
    Level will depend on room/budget (I've got two options)
  6. yant
    yant
    Dec 8, 2002
    264
    28
    +32
    --->Quad 12L+11L
    I really like the Quad, I almost bought some but went Dyns instead. If money is an issue, I don't think you need the 12L. 4 11L would be a great setup.
    ---> MA S2+S1 +SLCR =~ £920
    ---> MA B2+B1 + B centre =~ £420
    May I suggest:
    MA S1 + B1 + SLCR =~ £680
    So £260 more than a Bronze setup but still £240 less than your "level up" setup. I reckon you are due a visit to your dealer to compare :D
    Yan
  7. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I was allmost decided on the MA Silvers...
    But the Quads here are cheaper... and are amazingly transparent and clean...
    I also had in mind your suggestion... ;-)
    The Dyns are out... an AVReceiver is too weak for their sensitivity...
