Quantcast
Opinion for the KEF PSW 1000 Needed
D
drdm12345
Dear all. I am after the Kef PSW 1000. My room is small (3.8X3.9X2.1) WXLXH
Do you think that this sub will be OK for my system?
Marantz SR5200
Mission 77c1 X2 dentre fr & back
Mission 771e (front)
Mission 77DS (surround)
Many thanks Dimitris
common
I think OK is the operative word - doesn't really go down that low. I would suggest if your going for a sub, save a few more quid and make it a real upgrade rather than something you will replace in a few months time.
Loads and loads of threads on which sub's to try but the favourites seem to be:
MJ Acoustics Pro 50
A CHT10 from UE in the powerbuy section
Second hand RELQ100 / 50
D
drdm12345
Cheers for the reply. I used to own a Paradigm PS1000 which was really too much for my room. I want something discreet and visually pleasing as I face a lot of yapping from my wife!!
I thougt the KEF is small enough, down firing and in cherry as are all my speakers.
Thanks for taking the time to reply and helping me out. Dimitris
common
No worries - the MJ acoustics is small enough to get that all important wife acceptance factor and has quite a few fans on this forum. Also available in cherry I think
