Operating noise of HD5
Discussion in 'Headphones, Earphones & Portable Music' started by zenmod, Jun 14, 2005.
  1. zenmod
    zenmod
    I got the HD5 the other day.
    I noticed a clicking noise while, e.g. the player is reading the toc or while you switch tracks or albums.
    Since it's merely recognizable, it's really no big deal.
    I was just wondering if that's normal and if you guys owning an HD5 notice any operating noise as well.
  2. floppydonkey
    floppydonkey
    May 24, 2005
    53
    +8
    Yep mine does the same. but with cracks. :thumbsdow
  3. zenmod
    zenmod
    Sorry to hear about that. I specifically got the black one to avoid cracks. No signs of any so far.
  4. HMHB
    HMHB
    Nov 11, 2001
    25,516
    Nottinghamshire
    +3,852
    That noise is more than likely the sound of the hard drive spinning up in order to read more data, just normal operational noise unless it's really loud !
  5. L11
    L11
    Jun 2, 2005
    323
    +7
    Theres operational noise through the headphones when the power cable is plugged in, but none otherwise..
