Question Openbox v8s newbie need help
Discussion in 'Satellite TV, Sky TV & FreeSat' started by thequeenscheese, Nov 4, 2016.
Tags:
  1. thequeenscheese
    thequeenscheese
    Dec 4, 2011
    97
    11
    No, I picked one of these up for my dad so he could upgrade his freeway to freeway HD and record, my issue is findifinding a chennel list that simply replicates freesat, I've tried the satalite install for fta but that leaves everything in a very bad random order with duplicate stations, I've also tried the network upgrade of the channel list with the available file from the openbox site but that just installs the this list with all scrambled channels?
    Any help appreciated imreally don't fancy spending hrs and hrs rearranging and deleting them manually.
    Also will the v8se firmware workmon the v8s ?, as this is the only fw update that shows up in update over network.
    Thanks ..
  2. logiciel
    logiciel
    Feb 2, 2008
    53,092
    UK
    +5,752
    freeway?
  3. TJT1
    TJT1
    Jul 29, 2011
    4,643
    East Sussex, UK
    +1,084
    Google doesn't help much either.
    If you want to replicate freesat, why didn't you get a freesat receiver?
    Googling v8se comes up with OpenBox stuff.
  4. thequeenscheese
    thequeenscheese
    Dec 4, 2011
    97
    11
    Freesat tut not freeway, I got this because it was cheaper and suggested it gets freesat, I'm fairly tech and computer savvy but no little about satalite receivers.
    I've googled the issue countless times with not much answer tbh.
  5. logiciel
    logiciel
    Feb 2, 2008
    53,092
    UK
    +5,752
    For Freesat you need a Freesat receiver, which doesn't cost much.
  6. TJT1
    TJT1
    Jul 29, 2011
    4,643
    East Sussex, UK
    +1,084
    It will receive free to air (FTA) satellite transmissions, most of which are in the freesat/Sky EPGs. Freesat is not the correct name for the FTA channels neither is FreesatFromSky.
    Freesat is an EPG that lists the FTA channels that pay them to appear on their EPG. Freesat decide the channel numbers that the various FTA channels will appear on their EPG and provide a 7+ day content in the EPG. Freesat does not transmit content, just the EPG.
    The reason that your box is showing the FTA channels in a semi random order is that it lists them in the order that it 'picks them up' from the satellite. A Freesat box EPG sorts them in the order that we all know and love (or hate).
  7. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,636
    Cheshire
    +1,074
    You can edit the channels yourself into a decent order- mainly with the MOVE command. Not many people think the order of channels on Freesat/ Freeview, Sky or VM are that good any way, with that box, you can at least move the channels to the order you like or your father does, then I'd add favourites eg ENTERTAINMENT MOVIES DOCU TV KIDS etc..
    It does take a while at first, but once done, it's much easier to keep the one satellite up to date.
    Or you can search the net some more & find someone else's channel list to download & put in the box & maybe edit it a little.
  8. thequeenscheese
    thequeenscheese
    Dec 4, 2011
    97
    11
    In the current list he has now that I've rearranged (presuming these are fta etc Dave, and itv 2,3,4 in hd are not there which I would have thought should be?
    There were some channels that had random long numbers instead if station names which I deleted I'm guessing these were not those?
    Does anyone have a better fta list they can upload for me?
  9. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    They are not there because they are subscription channels on satellite. Dave is only free on terresrial UHF TV (Freeview)
  10. Fred Smith
    Fred Smith
    Apr 23, 2004
    2,294
    Reading
    +406
    As above Dave, ITV2HD, ITV3JD and ITV4HD are subscription so you wont see them on Freesat box.
    Don't know of a Freesat listing but there is CWAITE's Sky Numbered Channel List:
    CWAITE's Sky Channel List
    Which gets updated regularly.
  11. thequeenscheese
    thequeenscheese
    Dec 4, 2011
    97
    11
    Thought it might be but wasn't sure.
  12. thequeenscheese
    thequeenscheese
    Dec 4, 2011
    97
    11
    Another question, is there a setting for partitioning the hdd? The box doesn't record at the min as it says it needs partioning to record..
  13. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    Do you mean formatting rather than partitioning? What size is the HDD and what file format is on it at present?
  14. thequeenscheese
    thequeenscheese
    Dec 4, 2011
    97
    11
  15. LJx
    LJx
    May 29, 2009
    3,260
    uk
    +439
    You need to plug in a HDD or USB stick to record, I got one on those boxes and they don't exactly have a good user interface, hard work TBH, I bought an enigma2 box a week later
  16. TJT1
    TJT1
    Jul 29, 2011
    4,643
    East Sussex, UK
    +1,084
    That's possibly why you should have paid a little bit extra and got a Freesat badged box if all you want is Freesat. The advert to which you linked is possibly in breach of some advertising rule or other, as it's not a Freesat(r) box but a FTA box. It also says in the spec:
    Code:
    Support PVR(store in USB disk).
    Note the not particularly clear requirement for external recording media.
  17. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,636
    Cheshire
    +1,074
    How much do Freesat boxes start at with recording?
  18. JonMace
    JonMace
    Nov 20, 2002
    2,575
    83
    Kent
    +211
    The box you got is used in the UK to get a full sky package without paying for it
  19. thequeenscheese
    thequeenscheese
    Dec 4, 2011
    97
    11
    Ah right, recording is no biggie, I'll get pops a fire stick for Christmas anyway so he can have the i player etc and kodi...
  20. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,987
    +1,168
    If all you want is Freesat then return it. The Humax HB-1000S is £79 new or £39 refurbished from Humax Direct. This is official Freesat so you'll have no channel list to manage, 7 day epg and recording and series linking with additional storage attached. Also has online services like iPlayer.
  21. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    There is a better version of the Openbox for UK free TV - the V8S Combo - digital satellite, digital terrestrial and IPTV in one box. You can set up "favourite" lists with a mixture of satellite and terrestrial channels. Still no 7 day EPG on UK TV from on air (merely "Now & Next) or updates to channel lists when frequencies etc change and takes a while to setup but once done fairly easy for even a novice to navigate. If connected to web can also be set to download 7 day EPGS for various countries (and more than one) including the UK.
  22. logiciel
    logiciel
    Feb 2, 2008
    53,092
    UK
    +5,752
    Kevkbuk offers by far the simplest solution.
