Open Range
Discussion in 'Movie Forum' started by Mr_Tony, Sep 6, 2005.
  1. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    I brought this on dvd the other day and for some reason the sound is really quiet when coming through my amp, whenever I put in any other dvd the sound is fine, has anyone else noticed this?
  2. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    Have this on R1 and sound is fine.
  3. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    hmm i might have to try it again, is it a good film?
  4. Rolo Tomasi
    Rolo Tomasi
    Dec 13, 2002
    215
    +4
    The sound level is very low on this R2 dvd and I think it has been discussed in these forums before.
    Speaking personally, I normally listen to dvds at -20 to -15dB. The sound level at -10 is very loud. I had to turn Open Range up to -8 to get a reasonable volume. I therefore think it is the dvd not your equipment.
  5. Mr_Tony
    Mr_Tony
    Jun 17, 2005
    113
    16
    i might go for the R1 disc then, wonder why its so low
  6. Steve N
    Steve N
    Feb 3, 2005
    10,801
    Peterborough
    +2,210
    I've got this.
    I thought it seemed a little lower (volume) than some discs.
    It's worth watching, especially for the gunfight at the end which has great sound effects - especially in DTS.
    If you have your amp set to uncompressed the gunshots are really effective.
    This movie is on the "movies to test your system" thread.
    I wonder if the volume was deliberately set low to get you accustomed to this level so that when the shooting starts the effect is so much more startling.
  7. the_pauley
    the_pauley
    Nov 7, 2002
    4,066
    +198
    It is a pretty subdued movie for the most part - not loud at all, but that's intentional.
