open/closed headphones,whats the difference.?
Discussion in 'Headphones, Earphones & Portable Music' started by ianlecompte, Jan 17, 2005.
  1. ianlecompte
    ianlecompte
    Sep 17, 2002
    954
    oxfordshire
    +13
    as the title says really.
    cheers
    ian
  2. AlecF
    AlecF
    With closed headphones, the driver housing is sealed from the outside, and only "open" for sound on the inside, your "ear-side". Hence they help isolate you from sounds coming from outside; plus they don't leak so much sound out to other people.
    Open headphones are open in all directions, but you will still hear external sounds like the telephone, and they will leak sound out to other people.
    Generally, open headphones sound less constricted, but people may prefer closed headphones for use at work or late at night so as not to disturb others.
  3. ianlecompte
    ianlecompte
    Sep 17, 2002
    954
    oxfordshire
    +13
    thanks alecf,that really helps
    cheers
    ian
