oooooooooh it's quick!
Discussion in 'General Chat' started by stevegreen, Aug 8, 2005.
  1. stevegreen
    stevegreen
    May 14, 2001
    8,725
    in my Hymer
    +984
    Had my internet connection turned on today and just carried out the speed test at ADSLGuide.
    1628 mbps downstream :clap:
    It's a 2meg line so to get this kind of speed when i'm used to a 512 connection is amazing.
    All the wireless is set up, WEP encrypted, Happy Christmas!!!!
    he he he he :clap: :clap:
  2. ufitsy
    ufitsy
    Aug 18, 2004
    3,175
    103
    Midlands
    +335
    Happy Days : :smashin:
  3. seb
    seb
    Aug 5, 2005
    110
    16
    my computer at home is steam powered, its soooo slow. :(
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,710
    Galactica C.I.C.
    +223
    this one I am using at the moment has a crank handel to get it going :rotfl:
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    All this punch tape gets me down.
    Upgrading to card input next week...PJ :)
  6. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,714
    In a secret location with Jennifer Lawrence
    +7,493
    Lucky sod, my line will only go up to 1MB.
  7. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Currently visiting the old dear, she has 28.8k dial-up, quite a difference from 2mb bband I am used to :eek:
    What isa the difference between all the different encryptions on wireless internet then? :eek: :confused:
  8. Mindcrime
    Mindcrime
    Jul 27, 2000
    1,002
    Edmonton via Birkenhead, UK
    +120
    I best not mention that I am on a 5Mbps/800kbps line then had I:devil:. And all for the princely sum of $40 CDN per month!!!
  9. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    Ntl rolling out 10mb this year.
  10. Mindcrime
    Mindcrime
    Jul 27, 2000
    1,002
    +120
    If you read it closely it says "up to 10Mb" and no mention of cost either! Don't forget Bulldog advertise an 8Mb(?) line and yet most areas only get as high as 2.
  11. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    My 8meg/768k uncapped connection starts next week for the great price of £24.99 per month... cant complain
  12. Gary D
    Gary D
    Jan 9, 2002
    7,772
    +827
    i love my BB connection - it even makes the forum fast ;) not sure i'd make that much use of 8 meg.
    Gary
  13. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    Yea but ntl dont have conntention ratio's as high so u get what u have all the time.
  14. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    WEP, WPA-PSK. WEP a detirmined teenager can crack fairly easily as it works on password strings, WPA a skilled hacker can do in about 30 minutes. Nothing is uncrackable, it's just that nothing at all is asking for trouble. Using WPA (if your Router/AP supports it) is advisable for the above reason.
  15. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I havn't gotten around to encrypting mine yet but have disabled the SSID broadcast (I know Netstumbler will find them anyway) and locked the router down to the relevant MAC addresses and disabled any further IP provisions. Both of which are fairly easy to crack by the knowledgable but will deter any passers by. :)
  16. stevegreen
    stevegreen
    May 14, 2001
    8,725
    in my Hymer
    +984
    The WEP encryption on the Netgear router and wireless 'dongle' was extremely easy to set up so having a realtively secure network took about 10 minutes.
    If someone wants to log into my router now, they will need my password, which is not an easy thing to crack. Is there any worth in assigning MAC addresses too, which will again limit connections, or would this be overkill?
  17. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I'd definitely recommend assigning MAC addresses. Each wireless adaptor (or network adaptor for that matter) has a MAC address so by limiting these on the router, only your specified wireless adaptors can access the router. Similarly, limiting the IP addresses so that there aren't any free ones has a similar effect although both methods can be spoofed by a keen hacker. :)
  18. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Same here :(
  19. stealther
    stealther
    Mar 24, 2002
    2,058
    Lichfield
    +93
    Your in the midlands and you didnt tell me? I am hurt :( :(
    Planing to slip back to Devon quietly where you?
    Its ok I know when I am no longer loved goodbye cruel world :suicide:
  20. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    Just so you know, WEP has recently become very easy to hack. Previously brute force was required to break it, more recently there are tools which can pick out the WEP code from the signal however. A recent demonstration with tools commonly availible on the internet took 3mins to break 128bit WEP with a completely secure key. http://www.tomsnetworking.com/Sections-article111.php
    WPA however still requires over an hour and quite a lot of data (more than normal data transmission), however it is possible to completely freeze a WPA connection such that nobody can use it. This requires a simple signal to be sent to the access point and that makes the wireless part of it reboot.
    Hiding the SSID does not increase wireless security at all to be completely honest.
    MAC address control can increase security quite a bit if combines with WPA (perhaps WEP) but on its own it does very little as it is so easy to close a MAC address.
    Ultimately any wireless encryption is crackable as overkill said. However, if at all possible always use WPA as it is now SOOO easy to break WEP. I could even do it in 10mins on my tiny PDA with its processing power!
