Only three mounting holes on LE32A457...
Discussion in 'Home Cinema Buying & Building' started by captaindarling, Feb 12, 2009.
  1. captaindarling
    captaindarling
    Feb 12, 2009
    5
    Hi all,
    New here so be gentle!
    I have just bought a Samsung LE32A457 and a suitable wall bracket but have now noticed that there are only three mounting holes in the back of the tv. The bottom right has the hole in the case but is 'blind'. I have now drilled and tapped it M6 but the material is actually plastic not metal like the other three. Now not sure if this will be ok?
    Has anyone else had this problem?
    Many thanks
  2. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
    Strangely there's another thread on here regarding missing fixing points in a Samsung.
    Samsung TVs are a VESA standard and that means that there should be 4 metal threaded inserts available for the wall mount. If there aren't then it sounds like a product problem.
    In theory, your TV should hold on the 3 fixings but I wouldn't risk it myself, if the 4th fixing is missing you don't know what else may have been assembled incorrectly.
    Hope this helps
    Regards
    Graham
