only got mono sound
Discussion in 'Cables & Switches' started by malcmall, Oct 7, 2004.
  1. malcmall
    malcmall
    Oct 7, 2004
    61
    :hiya: Just had a 42 inch lg rz 42px11 plasma tv and a hitachi dvd video player
    also got an NTL box (changing to sky plus) at the end of the month
    i have a scart from me dvd to the tv and another from me dvd to me ntl box. Also got the aerial lead from the ntl to tv for me terrestial channels. Everything is fine except i can only get mono sound through me ntl box. got nicam stereo thru terrestial and brilliant sound when the dvd or video player is being played. Any one got any ideas?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,527
    Somewhere in South Yorkshire
    +6,000
    Are you watching NTL
    a) via the AV input on the TV or
    b) via the RF cable - i.e. via a "tuned" channel?
    If the latter then such a signal will indeed be mono only.
  3. malcmall
    malcmall
    Oct 7, 2004
    61
    Thanks for that! how do i get it stereo? as it seems it is via the rf cable!
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    by scart is only way do you have ntl digital or analogue....
  5. malcmall
    malcmall
    Oct 7, 2004
    61
    NTL digital!
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    have you got a scart from TV scart on ntl box to TV? do you have RF feed from ntl box to anything??? If you do disconnect it....
  7. malcmall
    malcmall
    Oct 7, 2004
    61
    Thanks for that horny dragon. I have a scart from ntl box to the tv (AV1) and scart from ntl to me dvd is this what you would recommend? Both scarts are gold plated.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    IS DVD a recoder or just a player? HAve you hecked silly things like software options on ntl box for sound outputs? does you box have L + R audio outs?
  9. malcmall
    malcmall
    Oct 7, 2004
    61
    The machine is a dvd player and a vhs recorder with progressive scan the sound is good now I have took out the rf lead but the faces close up are crap!
  10. malcmall
    malcmall
    Oct 7, 2004
    61
    but this is only sometimes....as you can guess I am learning normally you but a tv connect it and watch!
  11. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    If the pictures aren't very good you may be looking at a composite signal which is the worst quality. Make sure that the NTL box and DVD Recorder are both outputting an RGB signal which is considerably better
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I think part of the problem is they way you are connecting the combi try cable direct to scart input and VCR scart into VCR on Cable box and DVD output to component input on LG...
