Quantcast
only 73mins DV footage on a DVD - can this be improved ?
vonhosen
Yes
You are not so much limited by time as quality.
The more you want to fit on the lower quality is going to be. 90 mins should be OK ,even 2hrs if your original footage is good quality & you are using a good quality encoder with ac3 audio.
