Online gaming PC help
Discussion in 'PC Gaming & Rigs' started by captaineyecatch, Jul 17, 2002.
  1. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    I'm trying to play some online games on my PC (unreal,soldier fortune,half life etc) But i cant seem to get a playble Ping rate.
    The best Ping i get is 380 and it averages at 450 which is pretty much unplayable. I'm using a 56k modem so i know i wont get good pings but surely i should be getting better than that??
    The isp i use is AOL does this make any difference??
  2. jag
    jag
    Try playing late evening/early morning and see if it makes a difference. Also try a different ISP, preferably one that is not as common.
  3. Guest
    Here's a little info
    Broadband is getting alot cheaper, 56k and gamin = the pits
    You have the lag my son :D
  4. lechacal
    lechacal
    Aug 13, 2001
    711
    Cheltenham
    +66
    Where are the machines you're trying to play on.
    If you're trying to connect to the states you'll get terrible pings. Try more local machines(?).
  5. jag
    jag
    I actually only have a 56K Modem but use NTL. And although you get the occasional lag more often than not it is still fairly playable. There are so many servers for games like UT etc. that you can go for the low ping ones without any trouble.
  6. captaineyecatch
    captaineyecatch
    Feb 9, 2002
    2,013
    38
    South of Heaven
    +21
    Thanks for the help. I cant get broadband as i live in a village so thers no cable and BT wont upgrade the phone exchange till they get a lot of broadband orders (as i'm the only person to register my interest i think i will be waiting a loooooong time:mad: )
    The Games i'm trying to join are in the uk so lag shouldnt be a massive problem.
    I think i'll try a different isp.
  7. Guest
    before you chuck your current isp.......
    have you done a trace route or netstat to identify where your lag is coming from? is it inside your current isp's network or is it outside your isp's network?
    if you do a trace, post it so i/we can have a look.
    try using this program here, ------->"Ping Plotter" to diagnose your problem and pinpoint it to a specific node or router.
    if the lag is inside your isp's network then switching to another game server won't help. but you can contact your isp and try to get them to help you eliminate the lag. or just change to a different isp at this point.
    if the lag is outside your isp's network then changing to a diferent game server more than likely will be the easiest thing to do.
    good luck
  8. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    AOL = Lame
    AOL is the worst ISP to use for online gaming, I used to work for them :)
    Try some of the other ISP's you should notice a difference. Also, have you looked into ISDN? Although nearly the same amount as broadband it will give you a really good ping for online gaming (although download will still suck).
    For ISPs it is hard for me to recommend one as I have been using broadband for nearly 2 years, however it is worth looking at ISPreview.com and netfornowt (if it still exists). These were two good sites for cheap ISPs.
    I doubt you will get a nice decent ping if you do live out in the sticks mainly due to the amplifiers and wires you will be running through.
  9. fastercainy
    fastercainy
    :D hi i am a on line gamer also for 3 yrs im on AOL and never any probs. The probs youve got is that soldior of fortune is not a zone game www.zone.msn.com there the best server for on line gaming:D if its not on the zone then theres no one at home..sorta thing..go buy FS2002 and ill fly with yeah
