Onkyo Zone 2 output
MitsiTurbo
This should be very quick I would have thought...
You cannot use the Zone 2 speaker outputs in a 7.1 configuration which it says in the manual. What it does not mention is Bi-amped fronts in a 5.1 configuration which im assuming will not allow zone 2 to work either?
This is on a 605 by the way.
John
thenicklouse
Zone 2 powered or not?
MitsiTurbo
Sorry nick, its using the actual speaker outputs for zone 2, not the pre-outs to another amplifier. In wont let me turn zone 2 on in the setup menu. Im assuming thats what you were asking about?
John
thenicklouse
John
I have not got to playing with the zone 2 yet but i had a feeling that
Notes:
• When bi-amping is used, the AV receiver/AV amplifier
is able to drive up to 5.1 speakers in the main
room.
Might limit things. need to play ;)
samip
If you are using the front bi-amped, you can't use the zone 2 (because the amp only has 7 channels and you are using 4 of them on the front speakers). I want through the same issue a few months ago !
John
eddiem74
Found this thread, and have a Onkyo 605 Zone 2 related question so thought I'd ask.
Can Zone 2 only play analogue ?
I have a 5.1 set-up, and feed the Amp SkyHD and a HTPC via HDMI/Optical/Coaxial, however the only sound I can get from Zone 2 is the Tuner/Radio. I realise this is most likely as other feeds are digital, however anyone got around this ?
Are all Onkyo's amps this way ?
Cheers for your thought's ! :smashin:
james.miller
the onkyos have 7 channels of amplifications (from the 605 to the 905). this means you can either have 5.1 + powered zone two, or 7.1 + no zone two power, or 5.1 w/bi-amped fronts + no zone two power.
you can still run the zone two line out to an external amplifier though.
edit: also yes, only analogue unfortunately. i think i have a solution but it wont work on the 605 because the 605 doesnt have pre-outs.
