WibXL
At the moment I'm using an ancient Videologic Digitheatre set of 5.1 speakers plus matching decoder for my surround sound and a TV with only one DVI input. So far I've managed to get around lack of inputs by using a DVI switch and a separate toslink switch for the audio but I've reached the point where I don't have enough audio or video inputs and it's getting to be a pain to manually switch and swap inputs so I've been looking at getting an AV receiver.
I like the look of Onkyo's TXSR506 but I'm skint at the moment so it'd be a couple of months before I could afford it and even then it would just be the amp with no speakers at least for the time being so I wanted to know if it would be possible to use the speakers that I have as a stop gap solution.
The Onkyo is rated at 7 x 75 (8 ohms, RMS) whilst the speakers are 7.5watts at 4 ohms. I know that this wouldn't be an idle solution if it worked but for the time being it would be ok so long as the speakers would work and no damage would be caused to the amp.
Would this be possible?
