Onkyo txsr 606...is it on its way out??
malk
Hi there,
I haven't been on this section of the forums for a while!!!
My 606 , for the 2nd time, has cut out due to it getting too hot., i knew these amps get hot, and i have had it since release, and I've had the HDMI board swapped out.
Im thinking its on its last legs, and as I've cut down to a 2.1 set up,thinking i should think about getting a newer AV amp..
I was wondering if anyone else has had heat cut out issues, and if so, did the unit give in not long after...
Also, I've been out of the AV amp loop for a while, is there any half decent amps that have about 3 or 4 HDMI ins and a HDMI out?
Im using a SKY HD box.,PS3, and an Apple tv3..i was using optical for the ATV as i use iTunes match on it for music, but the sound difference wasn't that different to HDMI..
Im looking at 2nd hand, just don't really know what id be after....(looking at MAX £200)maybe less if the missus finds out!
Thanks for reading guys
malk
Oh, I'm using Monitor Audio BR5's with a Dali 100 sub..
