Ops thinks theres some confusion here..
I only have today to decide as I need to go buy Saturday.
My brother has
- Pioneer amp not sure which one cost near £1500.
- Gold In-wall Monitor Audio Speakers he said they cost like £750 each?
My friend has
- Onkyo 808 amp
- Unknown speakers
Both setups sound good.
What i am thinking of buying:
- Onkyo 808 amp £650
- Monitor Audio Silver W380lcr in wall speakers £300 each
Sub and rear speakers will need to wait a few months.
My brother recommended I should go for the silver as this will be sufficient for my needs. Amp I found based on as it was recommended by my friend, and as its end of life it will be reduced in cost also another benefit.
I will at a later date find a sub and rear speakers.
Can someone please put me some links up for decent but not too expensive speaker cable..i will also do the runs for the sub and rear speakers at the same time
Installation:
I will be cutting out the plaster board in the living room, little bigger then my 50 plasma, and the plasma will be mounted as close to the wall as possible. The left right & middle speakers will also be mounted in the wall by cutting the holes.
I will then create a thin floating wall as I dont want it to come out too much as space is limited. In the false holes will be cut for the TV and 3 speakers. I was thinking of putting speaker covers on the front for show however the actual speakers will be behind it in the actuall wall..
I will post my thinking of install in the DIY section, as I will need help with this.
Appriciate all the help, just hope i get it all right, as this is costly..
