Can anyone tell me if the TX-SR605E has the ability to output all inputs over the single HDMI port, or does it just do this for the HDMI inputs..?
I need component to be output over HDMI as I only have the 1 cable to my display.
Thanks/...
Is it possible to get it to pass the component signal through to the HDMI without doing any scaling on it? Skihood connected to the 605 via component then output by HDMI looks a fair bit different to when connected directly to the panel.
So 720p into component should look almost exactly the same coming out of the HDMI? The image seems to be much 'redder' now coming through the amp. I have fiddled with the TV settings yet so could just be that. Ideally id just like whatever goes into the component inputs to come out exactly the same on HDMI.
Thanks Jon
