Quantcast
Answered Onkyo TX-SR309 not 4K compliant
Caher
Hello all,
please excuse the obvious question but this is not really my area of expertise.
My Onkyo TX-SR309, it seems will not allow pass through a 4K picture from a YouView receiver so I was just wondfre5g how to get around this other than buying another one?
thanks
gibbsy
I know nothing about your box but if it has a digital optical as well as HDMI then a connection from the box to the TV will give 4K. Optical will give you SD sound only. All depends if the YouTube box has optical out.
Caher
Hi yes, it has an optical port in both the AV receiver and the You View box. So maybe I need to save up and buy a new AV receiver to get the best quality sound.
thanks
gibbsy
Yes. If you want 4K and HD audio then you will have to invest in a new receiver.
