Onkyo TX-SR307 - remote control question
Rickster1978
Hi all.
I'm not sure if I've picked up a decent deal or not. Grabbed an Onkyo SR307 from currys outlet for £37. It's an unbowed jobby but seems to all be ok. Just tested it with some speakers I had and works fine.
I've managed to download a manual from the Onkyo site so thats one problem sorted. Ive also got hold of a setup microphone off a friend so that's another problem sorted. The last issue I have to solve is getting a remote control. I've found a few around the £30 mark, is there any other option, for instance will any of the learning type remotes work for it, or has anyone got an old remote lying around that they no longer need.
Also if anyone's got this receiver is it possible to set it up without the remote? Only really looking at it for surround sound for the ps3 and sky HD. I'm aware it's not the newest or best model out there but for £37 it seemed like a good deal.
Any advice would be greatly appreciated.
Thanks in advance, Ricky.
Rickster1978
Thanks for that Andy. I'll get on the logitech site now and see if it'll do the job. The play one is very cheap, just wondering if there's much difference between the 300 and the 300i.
