HoopersXcalibur
Hello everyone, I recently purchased a Panasonic UDP820, everything was fine until i put in Alien which uses HDR10+ but, the player was only outputting HDR10. This was weird because i have a Vizio P series quantum which supports all the major HDR formats including HDR10+. So i eventually realized that my AVR (Onkyo TX-NR797) like most does not support HDR10+. What i ended up doing was connecting the audio hdmi (audio only) of the 820 to the reciever and the video hdmi straight to my TV. This fixed the issue. However now im running into an issue where no audio comes out of the reciever if both the AVR and the bluray player are connected to the TV. For some reason the audio keeps coming out of the hdmi input where my AVR is connected to the TV and stops when i change to the input i assigned seperatly for the 820. The only way i found to fix this was to disable the hdmi out going to the TV from my AVR or turning off UHD color of the input connected to the reciever thats connected to the TV and leaving UHD color on only for the input connected to the bluray player to the TV. This is a problem for me however since i need that hdmi to work since all my other devices are connected to the AVR and passed to the TV via HDMI. Is this something that can be fixed? Thank you.
