Apologies - I can't see a dedicated thread for one of these yet. So here goes.
I originally posted my Q in the AV Amplifiers and Receivers section here
http://www.avforums.com/forums/av-a...3-onkyo-tx-nr709-zone-2-speaker-question.html
As I thought it was a speaker switch question - it started as that but then morphed specifically to the 709
So here's my question
Zone 2 stereo speakers will be connected via dedicated Front L/R Wide (as per manual)
Zone 1 7.1 will be connected via dedicated Front L/R, surround L/R, rear surround L/R, centre, sub
It appears that to use zone 2 it needs to be set as on/powered in the menu - so I'm thinking that when I want it I can power it on and power it off when not wanted.
Manual says - Zone 2 - This setup allows 5.1-channel playback in your main room and 2-channel stereo playback in Zone 2, with a different source in each room. This is called Powered Zone 2, as the Zone 2 speakers are powered by the AV receiver.
It's just not clear in the manual if Zone 1 can still be used as 7.1 if the Zone 2 speakers are connected but not on.
or
If I turn Zone 2 powered off - does the amp then think I have Front L/R high
Unpacked it last night and updated firmware - first chance to replace old amp will be tomorrow - so I might have to wait and see.
or
