Onkyo TX-NR646 Help/question
Discussion in 'AV Receivers & Amplifiers' started by addyeddy, Jun 28, 2015.
Tags:
  1. addyeddy
    addyeddy
    Apr 10, 2007
    356
    43
    +119
    Can someone help me with a problem I'm having with my new Onkyo receiver? I have discovered on the Onkyo website that there is a firmware update available,via USB only.
    I've downloaded the files to a USB stick, but when I go to the Firmware update in the OSD, the options to update via NET or USB are both greyed out.Also when I click on the firmware verison, it says unable to check for firmware update!
    My network is connected to the receiver at 99% strength, so that's not the problem, does anyone know what it could be?
  2. simonlewis
    simonlewis
    Jul 31, 2014
    4,705
    stockport
    +1,757
    I have just been onto onkyo's website have you followed this ?
    Note: Please remove the wired/wireless connection before updating through USB.
    Please prepare a USB storage device such as a USB flash memory stick. You need at least 64 MB of available space to update the firmware. Please unpack the ZIP file onto an empty USB Stick which has been formatted with the FAT file system.
    We hope you enjoy the improved functionality this update provides to your AV Receiver.
  3. addyeddy
    addyeddy
    Apr 10, 2007
    356
    43
    +119
    Yep, exactly as they say.Nothing happens when I insert the USB stick.
  4. iceplayer929
    iceplayer929
    May 27, 2011
    4
    Hey guys, it is a USB only update. Make sure you disable all internet conections (wifi+wired) in the network settings, then attempt the USB update. Worked for me! :)
  5. addyeddy
    addyeddy
    Apr 10, 2007
    356
    43
    +119
    Done all that to no avail,anone got any other ideas?
  6. addyeddy
    addyeddy
    Apr 10, 2007
    356
    43
    +119
    Ok, managed to sort this, it was the USB stick I was using.Have used a Sandisk and seems to be well.
  7. simonlewis
    simonlewis
    Jul 31, 2014
    4,705
    stockport
    +1,757
    Glad you've got it sorted addyeddy.
  8. addyeddy
    addyeddy
    Apr 10, 2007
    356
    43
    +119
    Thanks, it was a relief! I'm enjoying the sound of this receiver immensely,and didn't want anything to be wrong with it! It's way better than my previous Sony DN-840.
  9. jeddati
    jeddati
    Mar 8, 2006
    827
    London
    +89
    Hi All It says the firmware update take 30 to 40 minutes ?? that's a long time considering it's local image on a usb. Is that how it really takes?
  10. danceriddle
    danceriddle
    Oct 14, 2010
    23
    3
    +8
    About 5 minutes.
    About 5 minutes
  11. ricky121
    ricky121
    Oct 24, 2010
    103
    +4
    Has anyone had any HDMI handshake issues with their onkyo / sky box / tv?
