This is probably a simple fix, but when you've spend so long on a problem sometimes the fix is staring you in the face and you can't see it...
All audio formats work perfectly, including DTS-MA 6.1 on Star Wars, LOtR etc.
DTS-ES on DVD works fine it seems too.
But Wall.e has a DTS MA 5.1 stream that shows as ES 6.1 and I get no audio.
Furthermore, the Sony Players I have identify it, but the Onkyo doesn't even recognise an audio stream, just blank.
Stick the disc in the PS4 (set to PCM mode) and it converts it to PCM 7.1 and the receiver picks it up so I know the disc is ok.
What am I missing?
What am I missing?
