Answered Onkyo TX-NR626 Question/Help
Discussion in 'AV Receivers & Amplifiers' started by bays2112, Jun 15, 2015.
Tags:
  1. bays2112
    bays2112
    Mar 24, 2010
    4
    Hi everyone,
    I have a tx-nr626 and when i turn it on to the BD/DVD input it will stay on that for maybe 5-10 seconds and then switch over to TV/CD and stay and then i will change it back then its the same motion over and over again. Ill turn it off with the BD/DVD and when i turn it back on it sometimes stays or i have to go keep turning the receiver on and off to get it to finally stay. The BD/DVD input has a PS4 attached to it through HDMI and The TV/CD input has xbox one connected to it through HDMI. Is there some setting that is making this occur, is it RIHD? If anyone could provide me some insight that would be awesome. The receiver is about 6 months old. Thanks
  2. Best Answer:
    Post #2 by dante01, Jun 15, 2015 (1 points)
  3. dante01
    dante01
    Mar 5, 2009
    46,566
    +11,225
    Best Answer
    It sounds as though HDMI ARC is switching the receiver to the TV source? Try turning HDMI ARC off or disabling RiHD via the receiver's HDMI settings.
  4. bays2112
    bays2112
    Mar 24, 2010
    4
    Thanks! that fixed it!
