Onkyo TX-NR609 hdmi output to VGA
markfay
Joined
Dec 4, 2011
Messages
7
Reaction score
Points
3
I have an ancient BENQ projector (PB2120) which I'd like to connect to my Onkyo HDMI output. The projector does not have a HDMI input. If I buy a HDMI to VGA cable would this work? It is the only way I can think of to get the menu's displayed (and reasonable-ish quality) without connecting to a TV which would have to be 'borrowed' from my lounge.
thank you
No such thing as a HDMI to VGA cable.
HDMI = digital. VGA = analogue.
HDMI to VGA converter = ££££££££££££
What about using component connections?
Though I don't think menus would work but you would get an image.
regards
Mark
I think my confusion comes from the fact that Amazon sell an HDMI to SVGA cable
http://www.amazon.co.uk/HDMI-Male-S...24P4/ref=sr_1_3?ie=UTF8&qid=1323167700&sr=8-3
However looking at the tech specs it says
Technical Details
* This cable connect HDMI Male to VGA HD-15 Male with connecting Digital Video and Digital Audio in one
* *****NOTE: Your Video card must support digital signal output through VGA port function.****---- *****PLEASE NOTE: IF YOU ARE BUYING THIS CABLE TO CONNECT FROM YOUR COMPUTER TO HDMI TV, YOU WILL NEED A CONVERTER (NOT INCLUDED)**************
So I guess it's look at a converter or a new TV for my little 'cinema/ music' room.
thanks for your help.
— As an Amazon Associate, AVForums earns from qualifying purchases —
Lyngdorf MXA 8400 - Premium Power Amp Review Teaser #homecinema #poweramplifier #hometheater
Back
