Question Onkyo TX-NR3030 Or Denon AVR-X7200WA.
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by as1, Jul 18, 2015.
  1. as1
    as1
    Jul 14, 2015
    56
    9
    uk
    +10
    need help not sure which is the best all rounder
  2. ktmkid
    ktmkid
    Sep 5, 2013
    520
    Warrington. Cheshire
    +70
    Wow I have looked at the very same amps. Think I am edging towards Onkyo 3030, it seems to do it all with ease. And I have found a brand new one for £1250
  3. dr no
    dr no
    Mar 30, 2004
    12,953
    +7,398
    Single most future proofed high end all in one available now: AVR-X7200WA
  4. as1
    as1
    Jul 14, 2015
    56
    9
    uk
    +10
    wow would you like to us where for that price
  5. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,148
    2
    Normanton
    +6,447
    a lot depends on what you want
    if you want the cheapest priced AVR then the Onkyo takes it, if you want the best AVR available ATM then the Denon wins hands down imho
  6. dr no
    dr no
    Mar 30, 2004
    12,953
    +7,398
    Absolutely :)
  7. as1
    as1
    Jul 14, 2015
    56
    9
    uk
    +10
    but is 11 channel amp better than 9 channel as the denon processes the atmos channels if im right
  8. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,148
    2
    Normanton
    +6,447
    it's not just the amount of channels that determines if an amp or AVR for that matter makes it better than another one, their are a lot of other things to think about
    I'm not saying the Onkyo is a bad AVR though, if only for the EQ my money would be on the Denon unless your thinking of using Dirac or some other form of EQ
    I actually like the sound of Onkyo, especially with my speaker brand but other things make my choice Denon especially if using the onboard EQ
    Allan :smashin:
  9. as1
    as1
    Jul 14, 2015
    56
    9
    uk
    +10
    ok thanks. also is the HDCP 2.2 already installed on the wa version or does it need to be sent away
  10. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,148
    2
    Normanton
    +6,447
    yes it is, all "A" versions are ready to go without having to be sent for upgrade, I'd be surprised if you found a non "A" now to be honest with you, my stock flew out the door as soon as it landed
    Allan :smashin:
  11. as1
    as1
    Jul 14, 2015
    56
    9
    uk
    +10
    so who has the best deal and in stock of denon x7200wa
  12. Graham N
    Graham N
    Feb 24, 2004
    1,656
    Cornwall
    +308
    If you are concerned about HDCP2.2 did you know that the Onkyo isn't full bandwidth
  13. as1
    as1
    Jul 14, 2015
    56
    9
    uk
    +10
    very intresting thanks for that
  14. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,148
    2
    Normanton
    +6,447
    try a sponsor on the forum ;)
  15. IanW
    IanW
    Feb 28, 2001
    1,672
    Wiltshire
    +172
    Can't comment on the Denon, but having recently upgraded from Onkyo 875, I have to say that the new amp is flipping awesome. Whether watching Atmos or DTS-HD, the sound is amazing. The detail and bass levels are unreal.
  16. as1
    as1
    Jul 14, 2015
    56
    9
    uk
    +10
    have to agree having just got my denon 7200wa
  17. CedrictheDragon
    CedrictheDragon
    Apr 25, 2014
    60
    7
    12
    +7
    But I read it has excellent stereo sound in HI Choice and Dolby Atmos, only think is no DTS X or Auro, or am I wrong?
  18. CedrictheDragon
    CedrictheDragon
    Apr 25, 2014
    60
    7
    12
    +7
    How come? I'm sorry I don't really understand all these terms. What is full bandwidth?
  19. Ideal AV
    Ideal AV
    Jan 12, 2011
    11,148
    2
    Normanton
    +6,447
    full bandwidth is 18GBPS
  20. stevos
    stevos
    May 16, 2004
    6,218
    +595
    HDCP is the encyption standard used when passing signals over HDMI.
    For most 4k content they need version 2.2, hence HDCP2.2. It is the newest standard and only been out in the wild for a year or so.
    Full bandwidth is the data rate that the HDMI sockets supports, if you want 4k with all the new features like high dynamic range and greater colour space, you need full bandwidth.
    Hopefully that makes some sense.
  21. Bbos37
    Bbos37
    Mar 27, 2016
    192
    Malaysia
    +17
    Should go for the Denon.
  22. CedrictheDragon
    CedrictheDragon
    Apr 25, 2014
    60
    7
    12
    +7
    I'm now going two channel but thanks for all the advice guys.
