onkyo tx ds575
pewster
hi im having problems when switching channel or inputs. the amp loses sound and only comes on again after cycling through randomly. also on initial start up .any suggestions
PSM1
Sounds like you may have the common hdmi fault. You could replace the capacitors yourself and there is a good guide on u tube on how to do it. Otherwise it is a new amp.
pewster
hi psm1 my amp does not have hdmi or is that a generic term for the capacitors.could you please advise
PSM1
Did not clock that your receiver was pre HDMI but issue sounds very similar to the fault experienced on the HDMI boards. This would not be the same for you but may be a similar issue with capacitors getting too hot and failing.
pewster
thanks psm .in your opinion would you recommend a repair or replacement as its a great amp when working but is getting on a bit
PSM1
Hard to say but probably not worth paying someone to repair it. Will cost you £80 or so for someone just to look at it before even repairing it. Since you could get the equivalent current model for around £250 then probably should just buy a new one.
pewster
thanks for all the advise. gonna ditch it and dig out my pioneer sa8500 and go hifi again.cheers psm
