Onkyo tx-876 input mix
Discussion in 'AV Receivers & Amplifiers' started by mattyg, Jan 6, 2012.
Tags:
  1. mattyg
    mattyg
    Sep 26, 2006
    130
    +7
    Hiya Guys,
    Is there anyway to show video input from one channel but audio from another.
    Or in other words.
    Can I play my sonos through my amp whilst having sky on the tv. KRP-600
    Matt
  2. Mike2001
    Mike2001
    May 4, 2011
    138
    28
    +70
    Hi Matt,
    Don't know if this will help, but I've been using the CD input of the 876 to run REW sweeps from my laptop so that I can analyse the frequency response of my room and speakers. If I initially power up the system to watch SKY and then select the CD input with the original remote the audio comes from the CD input, but the video from SKY continues.
    So it appears that if a non video source is selected, the previous video input remains in force.
    Hope this helps.
    Regards, Mike (KRP500M)
  3. mattyg
    mattyg
    Sep 26, 2006
    130
    +7
    Cheers Mike I'll have a go
