Onkyo sx606 help
scoobydont
Hi all hope someone can shed some light,I have an onkyo sx606 which I bought off a friend but for the life of me I can't set it up to the tv which is a toshiba regza 46zv555d the only connection I've made is the headphones the av works it was working fine on my friends set up.i just can't get around the assigning bit and the fact that I don't get a menu on the tv I have a hdmi going from the tv to hdmi out on the av but get nothing is there's simple step by step guide to follow as I'm not too clever at this sort of thing.sorry about grammar but I'm posting on a phone and it's awkward with my fat fingers to navigate keyboard many thanks in advane
anorax25
If this model is anything like my previous Onkyo ( think it was a 605 ) you can connect an RCA phono lead to the yellow composite RCA socket marked 'Monitor Out'. That should then be connected to the yellow composite in RCA on the TV. You should then be able to change the source on the TV to composite and view the menus to assign inputs etc.
best wishes,
Col.
scoobydont
best wishes,
Col.
Thank you I'll give it a go
davepuma
Why don't you ask your mate to help you get it up and running? Do you have the manual? You should be able to download one from the internet.
The Eggman72
The 606 default output is composite..after you have the menu up via composite set it to hdmi...
scoobydont
My mates moved abroad hence the sale and I haven't got the manual my only Internet access is on the phone until my laptops repaired many thanks
scoobydont
Mates moved abroad hence sale and I don't have the manual also only Internet access is on phone until I get my laptop from the repairs cheers
davepuma
That is what you will use to get the amp's menu on screen. Connect the monitor out to the composite (video) input using a composite cable.
scoobydont
I've done that and nothing happens thank you for your time and patience the cable I'm using is the one I would use for the sub is that the right cable cheers
Curly99
iirc with my 605 when I got that and connected by HDMI to the TV the menu defaulted to display on the small LCD on the amp, not ideal but useful enough to allow you to set the menu's output to the TV, is this not the same?
Curly
scoobydont
Ok got said video cable conected one end in video out on tv and the other end in monitor out still nothing is it meant to override the tv and come on automatically or as usual am I doing something wrong cheers
davepuma
No you will need to select the AV input for the composite connection.
If you are still having problems, I would google for how to reset the AV Receiver to factory default. After that, it would appear to be faulty.
Curly99
I've just read the 606 manual and this bit is highlighted
The onscreen setup menus appear only on a TV that is connected to the HDMI OUT. If your TV is connected to the
composite video or S-Video MONITOR OUT, or the COMPONENT VIDEO OUT, use the TX-SR606’s display when
changing settings.
so it nogo using any other cable to view the menu.
Curly
Curly99
the manual is not very clear and from memory you need your TV connected via HDMI and then switch to menu, it will appear on the receivers LCD display then enter the 6.miscellaneous menu and the 2nd option is OSD which you select the TV output then the menu should if I am correct appear on the TV instead of the receivers LCD.
Curly
scoobydont
Ok tried what you said nothing happens may well be a fault although I can't see how as it was working perfectly before thank guys for your help anyway
Curly99
try this from the manual
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. “Clear”
will appear on the display and the AV receiver will
enter Standby mode.
that sets the receiver back to factory defaults, connect an HDMI cable from HDMI out on the receiver to HDMI 1 on the TV and select that input on the TV
then from the manual
Press the receiver button on the remote followed by the setup button.
The main menu appears onscreen.
Curly
Similar threads
Trending threads
Latest News
Acoustic Energy launches AE520 flagship speakers
  • By Andy Bassett
  • Published
Disney drops all 20th Century Fox branding
  • By Andy Bassett
  • Published
Kitsound launches Funk 25 wireless earphones
  • By Andy Bassett
  • Published
THX Spatial Audio app brings 360 degree sound to any headphone
  • By Andy Bassett
  • Published
Xbox Series X November launch confirmed
  • By Andy Bassett
  • Published
